Results 1 to 10 of 10
Thread: 8L90 Desired Slip
    Jan 2023
    2
    8L90 Desired Slip
    Hello all,
    This is my first post here on this forum so pardon if this isn't in the right location..
    I have recently started to get more into tuning. Specificly gen 5 LT1,LT4 and the 8L90
    I have been reading a lot of posts and messages saying that on a 8L90 the Desired Slip should always be 0 to prevent the known tcc stutter. Oke fair..
    But i am curious if i put the whole table to 0, if that affects the reliability of the TCC and the transmission.
    So i am hoping to gets some thoughts from you all.
    Thanks in advance!
    405
    2,315
    I just keep the converter unlocked in 1-5.
    Jan 2023
    1
    I'm getting a slight trans shutter during the 2 to 3 shift during normal to light acceleration on a 2016 A8 . Everything else work well .
    Can that problem be tuned out?
    Does the trans module need to be sent in and tuned.
    Thanks in advance.
    Aug 2009
    Calibrating
    3,373
    16 can be easily tuned, just pull trans file and tune it!
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Jan 2023
    Utah
    10
    I've run that table on 0 on several cars and it does fine. I don't see it effecting reliability. If anything it probably helps reliability not slipping.
    Feb 2023
    24
    Would someone be willing to post a screen shot of the desired slip table in HP Tuners on the 8L90? I cannot seem to find it and I know it's there somewhere. Thanks!
    May 2006
    Baton Rouge, LA
    84
    Quote Originally Posted by JoshC View Post
    ** edited **
    Are you referring to TCC Desired Slip? If so... Transmission > Torque Converter > General > TCC Desired Slip
    VCM Editor v5.0.4
    **Capt. Ron - 7th Dist. Fire**
    just because you zero out the tcc slip tables doesn't mean its still not slipping. you really need to do a scan while driving of the appropriate pids to really get the tcc dialed in
    they show you how to do it in the gm trans booklet over at the tuning school
    https://thetuningschool.com/apps/bundles/bundle/29391
    Jul 2018
    6
    Where can I unlock the converter 1 > 5? which tab, which setting?
    thanks
