Results 1 to 5 of 5
Thread: 2014 ram idle cam swap issues
    hi, I have a 2014 ram with the 5.7 hemi and it had cam and lifter failure. I replaced cam with mds cam replacement with non mds lifters. I have mds turned off. after replacing it I have been fighting a cylinder 6 misfire only code is p0306. It idled rough and would die when coming to a stop. I have checked ,swapped and replaced spark plugs, coils, injectors and have replaced the pcm and vvt and cam sensor the map sensor and throttle body as well. I checked for vaccum leaks and non were found. compression test was good it was 180 along with the rest of the cylinders on that bank. Pushrods were not bent and were fully seated in the lifer and no bent valves or broken springs. i took it back apart to check lifter and they are in good shape not collapsed and looks like the have oil going to them along with the cam that looks good as well. I dont know what else to check and any ideas on where to look next would be a big help.
    Sep 2021
    Florida
    64
    Valve seats or valve stem seals, exhaust leaks or head gasket and or combination of improper torque sequencing. Don?t forget to check the resistance to your injectors and coils and make sure they have proper timed sequencing signals, power and voltage then move on to check your crank sensor/wiring and did you perform the cam crank relearn process correctly.
    Jan 2022
    903
    its obviously sealed up it has compression what about the phaser and the control valve? was it replaced?
    [email protected]
    don tanklage
    Mar 2021
    Yuma. AZ
    82
    make sure your push rod is on the lifter in 6. it's very easy for them not to be on a liter and press off the block. pop valve covers off, bar the engine over by hand. look for a rocker that is not moving
    Aug 2021
    Yorktown VA
    196
    Checking to make sure that the pushrod on the lifter is a good suggestion. But it might even be more of a possibility that the other end of the pushrod may not be fully seated in the cup of the rocker arm also. It's easy to think you've got the pushrod in the rocker arm's cup but have actually just missed it and the pushrod could just be resting there and causing your valve in number 6 to not be opening and closing, causing a misfire. That being said, you really need to post at least a log with a little idling and a short drive where it shuts off like you're saying. I don't know that one cylinder misfiring would be enough to cause your truck to shut off on its own so it would probably better your odds for getting this issue sorted out if we were able to see the whole picture through a log, and even better yet, both your log and current loaded tune. And while I'm not proud to admit it, I've had to work through quite a few instances where my Ram was seeing misfires, stalls, rough idles, ect. You name it and odds are, I've seen it and had to sort through it already myself. Lol
    2016 Ram CCSB Forged NA 396ci Stroker
    +2.5cc Flat/Dome Mahle Power-Pak Forged Pistons w/13.2/1 CR on E85
    Forged Manley 4.05" Stroke Crank/Speed Master Valvetrain
    Race Ported Eagles/Titanium 2.12"/Titanium 1.62" Valves
    Custom Cam 235/249 .629/.629 111LSA 110ICL+1Adv
    Ported Holley Hi-Ram Intake/NXpress Hi-Ram NO2 Plate kit w/250 Shot(4 sec)
    Tx Spd 2" Long Tubes/Active Viper Hood/2-Step
    ATI SD w/15% UD/Dual 450 Pumps/Fuel Cell in Bed/Demon 700cc Inj
    3800 stall/Det Tru-Trac/410 Gears
