to anyone that might want to help!! 2007 tahoe 4.8 2wd
Recently bought a project truck. I didn't buy or install the parts but i got the truck with receipts and pics for a pretty decent deal. the truck had 300k on it with a bad lifter before motor was pulled to rebuild. full rebuild all new bearings pistons rings block and crank went to the machine shop not 100% on exactly what the did with the block i think just hone and cam bearings polished the crank stock rods. btr stage 4 truck cam v2 with springs ls7 lifters the heads were gone through all new valves. then what i think is a ebay truck turbo kit was installed. aem wideband and boost gauge in the truck. I just installed a qfs 340 fuel pump and converted to a regulated return fuel system referenced off the manifold. welded in a stainless -6 jic on the passenger side of the rail that goes to the return. while the rail was out i pulled stock injectors, decapped cleaned and flow tested them. they all looked good within 1-2% excellent spray pattern. I am a pretty good mechanic with yrs of experience welding and fabricating experience from building custom metal boats. Im also fairly tech savy. ordered the mpvi3 with 2 credits been doing a ton of research on tuning watching hrs of videos on youtube and from what i can tell so far its going to take me months if not years before i am where id like to be skill and knowledge wise on tuning. Id rather learn to tune and be able to continue to make changes than pay someone else a whole bunch of money and they might not even nail a perfect tune.
The truck will start and run. i havent tried to drive it at all just in fear of doing damage from the tune being so far off. I think the previous owner also did something with the tune but had no idea what they were doing so i dont know what may have been changed already just to get the thing to idle. Ran way better with the decapped injectors but now the idle is super fat wants to stall. Any how im not looking for this thing to make gobs of power or be super fast just want to get it driving as good as possible low boost maby 5 psi? Can i get away with the stock map sensor?
pulled the tune on the truck last night attached it. any help/advice would be greatly appreciated.
