Results 1 to 4 of 4
Thread: XDI 65% Injectors
    Jan 2023
    Utah
    10
    XDI 65% Injectors
    Does anyone have any experience tuning the XDI 65% injectors? It's not as simple as just upping the flow rate by 65% is it? Does anyone have any data?
    Aug 2009
    Calibrating
    3,373
    Ifr is only thing changed on these… I don’t agree with it, BUT it seems to work fine..
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Aug 2020
    Petersham, MA
    134
    That’s most of it, in a nutshell. Most tuners end up messing with the rail pressure at idle & low load to get the pulse width up a bit, but overall they’re way easier to setup than the LPE +52% ones.
    2017 Camaro SS, Whipple 3.0, Mast LT Black Label heads, 112mm TB, LPE BB HPFP & LT4+52% injectors, Fore Innovations triple pumps
    1059 WHP, 944 WTQ
    May 2003
    South FL
    1,369
    At minimum just update the flow rate. But you will likely need to adjust rail pressures at lower RPMs to keep the pulse width above 0.8ms, especially if you're on pump 93. I have found that you really need to adjust the flow density multiplier table to keep the injectors more consistent.
    [email protected]
    Owner/GM Calibrator
