Hi all
im having some issues with a swap i did on a 67 gto consist of:
Ls2 with e force supercharger out of o5 corvette
e40 pcm from a 06 5.3l buick rainier a/t
rebuilt 6l80e running stand alone tcm-2600
engine harness started as an aftermarket ls3/6l80 e38 harness that i repinned to use on the e40
gas pedal is for an 06 tbss or rainier
running 2 bar os with ford tmap
ive got the tune in the car to run pretty decent i adjusted some of the ve table and some of the maf table along with injector data airflow data etc. The problem is spark torque management, fuel cut torque management and etc torque management keep coming on even after i tried numerous different settings in the torque management tables. I reviewed some of the previous post pertaining to this issue and i believe my solution would be to do a change in os to a 06 ssr m/t. I cannot find an 06 ssr m/t. I have never had to do a complete change in os so this is new to me. Also note that the tcm and pcm do not communicate with each other theyre both running independently of each other. The car starts up fine idles fine and cruises fine even when it acts right i can hit boost but its not consistent half the time torque management wont let me get past 35/40 percent throttle. I found someone say it could be related to the pcm not having a vss input but im not leaning that way because just revving the car i can get the tq management to turn on. I feel that if i could keep the torque management off the car would run great. Just to add im still fairly new at tuning.
