RE: E38 fuel level
Hello,
I have fitted a VF L77 & 6L80 to my VZ 1 tonner, it currently starts, runs and drives no problems but have a couple of little issues I'm trying to work through.
Main OS 12656930
System 92271525
Speedo 92271528
Fuel 92271522
Diagnostic 92271519
Eng Operation 92271516
The fuel level readout in VCM scanner is always 0 (for fuel tank level ratio and volume) but it shows 2.09V on fuel tank level sensor 1 and 2. I read 171Ohms across pin 16 & 31 as well as 16 & 70 which is in range of the service manual (between 40 & 250 Ohms). So as far as I can tell, the ECM is receiving the correct input data not not generating a level output for some reason, what can cause this?
Am I trying to do something here that won't work?
I have attached a file.
