Results 1 to 3 of 3
Thread: unlocked TCM throwing p0700 codes
    Sep 2016
    391
    The car is a A10 2019 camaro SS, had a spare tcu sent to unlock & program from HP tuners, did the process and i got a p0700 code that no matter what i do wont go away.
    Also downloaded the latest beta, when i use that instead of the stable 4.xx version to tune the TCU the transmission has no reverse or forward gears is this because im using the OG mpvi to tune instead of my MPVI2 or is this a known problem that hasnt been solved?
    May 2003
    South FL
    1,371
    When I ran into this, I ended up having to send the TCM back to HPTuners. It was an issues with the off the shelf unlocked TCM. I assume due to some sort of incompatibility. So I had the client send in his original TCM to be unlocked and never had the issue again.
    [email protected]
    Owner/GM Calibrator
    Aug 2009
    Calibrating
    3,373
    Quote Originally Posted by TriPinTaZ View Post
    Yep I’ve ran into the same thing.
    I’ve also ran into an issue with no code, pull the TCM tune (it’s blank), write new progran and it pops up with check engine light that can’t be removed
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
