Results 1 to 2 of 2
Thread: 2018 STI with 207 swap incurable p0244
    Jan 2020
    39
    Tuning a 2018 STI and I have two issues.
    One is I keep hitting a fuel cut around 6800rpm and popping a p0244. That's the usual overboost code but no matter what I set the Boost Limits table to, including maxxing it, I keep popping p0244 right before 7000 rpm. Any fix for this?
    My second issue is the Closed-to-Open-Loop display tables are not present so I run lean on spool up to 3800rpms. Not ideal, any fix for that as well?
    2018 Subaru STI Tune Ext Features.hpt
    Tuner jaz|TUNING's Avatar
    May 2022
    Greenwood, AR
    57
    I gave up on Subaru on HP Tuners... It's never seemed ready and Cobb works.
    That said, the only odd thing I saw in your map is the WGDC dropping to 0% up top. Also, it doesn't seem to work like Cobb for Req Tq vs Req Boost in that you can't even reach the Req Tq X-axis in the Req Boost table. Have you tried rescaling the X-axis? Do you have a log comparing target vs actual?
    As seen through Cobb, where the Req Tq on the throttle map directly correlates to the X-axis on the Req Boost table:
    Sorry, I screenshot them backwards from each other.
