Results 1 to 4 of 4
Thread: wake up to this issue help from support?
    Jan 2021
    Miami
    351
    By the prickle of my thumb something wicked this way comes!2008 Chrysler 300c! 2013 heads/220/230 comp cam/LTheaders/FTI 2600 stall converter.
    Tuning Addict
    Jan 2015
    6,813
    Sound like virus software removed some pathways. Had this happen years ago. You'll have to delete then reinstall hpt to your computer. If support hasn't helped yet. At least that was what I had to do then.
    ~Greg Huggins~
    Advanced Tuner Cringer's Avatar
    Aug 2021
    Somewhere smoothing your VVE table
    517
    Reinstall VCM suite. Should fix it right up.
    A standard approach will give you standard results.
    My Tuning Software:
    VVE Assistant [update for v1.5]
    MAF Assistant
    EOIT Assistant
    Jan 2021
    Miami
    351
    i deleted and reinstalled 4x and it took but now i cant use compare and change anything, it says on read, if i remove compare i can change settings without having any file in the compare.
