Results 1 to 4 of 4
Thread: 2018 Tahoe 10 speed file - Only shows 8 in trans gear ratios
    Oct 2018
    3
    I have been provided with 2 separate 2018 Tahoe 6.2 10l80 Ecm Tune files. One is 2wd and the other is 4wd.
    When I look at either file in VCM editor, in the trans tab under gear ratios both files only show ratios for 1-8. I am using VCM Edistor 5.04 Why do the files not show all 10?2018 6.2 10 speed tahoe.hpt
    7,649
    Um, there's no trans controller included in that file.
    Oct 2018
    3
    Sorry, I should have been more specific. I don't have the trans controller yet, I am in the process of ordering an unlocked t87a with the correct programming for the 10speed.
    What I am questioning though is the ecm tune. More specifically the part of the tune under the Transmission>>>General Tab>>>>Gear Ratios. This part of the ECM tune for the 2018 10 speed tahoe file which I have only shows 1-8 on the gear ratios. (see attached screenshot)
    When I look at ecm tune files from other 10 speed vehicles (ZL1), they show 1-10 on the gear ratio tab in the ECm tune.
    I am just trying to confirm that I have the right ecm tune that will work fine with the 10 speed t87a TCM. I have confirmed the Tahoe vin and RPO list and the file I have is from a 10 speed vehicle.
    May 2006
    Baton Rouge, LA
    84
    I dug up a 2020 Tahoe LT (5.3/A6) file, and it shows "8", even though shift tables are limited to "6" gears.
    Gear Ratio
    1st - 4.0260
    2nd - 2.3621
    3rd - 1.5310
    4th - 1.1520
    5th - 0.8521
    6th - 0.6670
    7th - 0.6000
    8th - 0.6000
    **Capt. Ron - 7th Dist. Fire**
