Stratergy help HAEDU7 FG NA
FG NA+T using HAEDU7 Stratergy, I cant seem to import Speed Density Tables from other FG turbo Stratergies, I have tried as many as I can find in the Tune Repository but every time I copy over selected Tables and Save they still show up as differences in the comparison log. The tables show 0 in differences of values, axis have been swapped over but still different.
This seems to be a pretty standard tune procedure when going from NA to Turbo ie, Injector scalling, timing reduction, turbo logic and Importing Speed density and cam tables from a turbo file.
Not sure if its the lack of boost pressure sensor or the way turbo ecus calculate there aircharge but strange I cannot where others doing same conversion can
Any help appreciated at this point.
