Page 3 of 3 FirstFirst 123
Results 41 to 50 of 50
Thread: "DE-Tuning" 2005 Hemi - This should be a first !
  1. #41
    Quote Originally Posted by acln99 View Post
    Well the weather is finally good enough to do a real test drive. Car was just up on blocks before.
    Regarding the Torque Management issue, I am testing fooling the APPS with a couple of resistors to simulate reducing throttle pedal position. Seems to work but am getting a DTC P2138 - APPS Voltage Correlation. I need to refine my resistors !!
    Todays question is - Engine idles at approx 2000 rpm when I am coasting to a stop sign , foot off Accelerator Pedal. When I actually stop (or just before) RPM drops to 624 rpm just like is set in the idle tables. On a 2800 lb car, 2000 rpm is enough to keep it moving and you really need to use the brakes to stop. On startup, engine starts and immediately drops to 624 rpm as expected.
    Any help is appreciated ! Thanks .
    Attachment 130350
    The rolling cruise is from trq table stuff. Pull friction trq out where it coasts down at and the tb base voltage will follow for the less trq. Torque Model/Loss/Base table 12882.
    It is a jugle also so you might have to re do ve decel mapping and what not.
  2. #42
    Tuner in Training TaylorJ's Avatar
    Dec 2022
    Newtown pa
    22
    rays04gtx -- sent you a PM !!
    Ray can be a nite mare to get a hold of, nothing personal..........Azerbaijan starting Tuesday and he'll be there till 5/1 on his Consulting Gig,then off to Miami week of 5/3, at least he'll be state side till 5/15, then off to Emilia-Romagna region of Italy.......don't know about you but I would like a 6 figure retirement gig myself.
  3. #43
    Dec 2022
    Newtown pa
    22
    Attachment 130350
    Posting a Log will help a lot,
    Need Channels : Calculated Load, Powertrain request, Accelerator Voltage, Throttle Position (both Voltage and Percentage( ratio) and at least on of the Total Ve (bank 1 preferability).
    Couple of things going on here.
    your OS is getting mixed information as it's deaccelerating, it's been told it's a manual trans , which doesn't correlate with Tq request and load calculations feedback it's receiving........your sideways 904 has more "drag" then any manual trans.
    your APPS "mods" are disagreeing with Power%Request and Expected pedal tables, which on the way up is fine but once you let off the gas , it's acting like a chicken with it's head cut off.
    you set all Idles to 624 in 35500/35502/35504/35506 which is fine but Tables 35526/35528 have to match......... do your self a favor and tables 35520/35523 have values Higher then 624......which will confuse the computer when it needs those values.
    you say it's dropping to 624 just as you stop.......that's because @3 MPH the OS jumps to the Idle tables.......up the MPH in table 44216 and 12393 same value (IE 5MPH in 44216 and 12393) that'll help.
    P0700 is still checked in Mil column.
    Looking at your " Tune history there are some things that were changed prior to you buying/Receiving this ECU.
    [ECM] 12981 - Fuel Trim Cell RPM Hyst: RPM hysteresis value; is an issue............should 64000 RPM , no need to mess with it.
    [ECM] 44448 - FA WOT Delay VSS Min: Above this vehicle speed, WOT Delay is active; needs to be 127.5MPH , Not 15. the 04s by nature don't have a WOT delay, but with this table being Mapped out if the value is changed it negatively affects the WOT table.
    Idle>Air flow ............it ALL needs to go back to stock
  4. #44
    Mar 2019
    Ontario Canada
    34
    Thanks for reply!! - I looked up table Torque Model/Loss/Base table 12882. Don't actually understand it or why it exists. In my setup there is very little load on engine, A/C, alternator, ps and a very light car.
    Could I change all values to zero ??
  5. #45
    Mar 2019
    Ontario Canada
    34
    TaylorJ thanks for all the info - I didn't see your response when I posted just 2 hours ago.
    Yes - this is a used PCM that purchased with what I thought was a factory 56030033AI Flash. ( 2004 Ram 2500 manual trans )
    It was flashed into a PCM that was originally 56029161AC ( 2004 RAM 1500 Automatic without AWD transfer case. )
    I'm surprised that you can tell all that in the "tune" I uploaded !!
    LOL "sideways 904" - I agree ( actually - straight 904 in this model ) .
    Still do not understand why they take into account "drag" - unless they are trying to avoid - "engine braking" . I suspect that is a whole other topic with torque convertor lockup etc.
    I have disconnected the APPS mod for for further testing. I found the high idle while testing APPS mod.
    I changed the 35526/35528 to match and also changed 35520 & 35523 to 648 rpm.
    I changed 44216 to 5MPH - can I actually increase it to 10mph ?
    I can't find a 12393 !!
    Thanks for pointing out MIL P0700 !
    I corrected 12981 and 44448. I will look for a "stock" tune to compare more settings.
    Thank you for ALL your input !!
    Earlier today I tried to Flash PCM with a few changes suggested by JoshCP527 - ie 12882 .
    The Flash process failed on the ERASE phase. I now have to solve that issue first. It worked fine on the last update !!
  6. #46
    Advanced Tuner PurpleRam's Avatar
    Aug 2017
    Quakertown PA
    478
    VSS idle speed…… yes you can go to 10pm, don’t go any higher, what I would do is try 5,then 7,if need be 10mph,
    12882 , is a complex set of algorithms that includes, calculate load, power trainrequest, Tq airflow ……… those #s in the table represent the total Tq loss the engine is theoretically experiencing, since you have less “drag” now , you can decrease some of the lower rpm area’s in the table.
    Try decreasing some of the lower #s by 5%, see how it reacts BUT YOU CAN NOT zero the table. Also tq/airflow tables will need some attention eventually.
    04 GTX........ 8.91@151mph 392Ci G3Hemi NA 3600lbs 2.6HP/CI Naturally Aspirated
    05 GTxtreme 9:45@142mph 426Ci G3Hemi NA 4000lbs
    G3 Hemi Videos
    https://www.youtube.com/channel/UClS...5mXdDR5sOxs10Q
  7. #47
    Aug 2017
    Quakertown PA
    478
    Quote Originally Posted by PurpleRam View Post
    There will be spots on the 12882 table that can be 0 , but you can not zero the table, wanted to clarify that last post.
    G3 Hemi Videos
  8. #48
    Mar 2019
    Ontario Canada
    34
    It stopped snowing again and was able to test the updated tune. At startup idle immediately returns to 650 rpm. Turning on A/C - idle becomes 800 rpm.
    This is all good !!
    When driving at 40 -50 mph and let off on gas and put car in neutral - rpm stays at approx 2000 rpm until Vehicle speed drops to about 10 mph. Then drops to 650 rpm.
    Again - I would like rpm to drop when you take foot off gas pedal. Could this have anything to do with a "clutch" dis-engage switch. On a 2004 Ram with Manual transmission, does engine idle down when you press in the clutch at highway speed ??
    attached is my last tune.
    Thanks again for any and ALL help...
    2001hemiprowler-write3.hpt
  9. #49
    Mar 2019
    Ontario Canada
    34
    I looked up a 2011 5.7 Ram tune and saw that table 12882 was completely different.
    2011 values are a lot smaller but is based on Torque as opposed to MAP.
    Could this be my problem ?
  10. #50
    Advanced Tuner rays04gtx's Avatar
    Oct 2021
    Allentown PA
    363
    No,
    Try this tune, the changes are listed in the calibration details,
    as for the "loss table" what you'll have to do there is trial and error
    Attached is your current table, I would try and reduce Tq values by .95% in the red circled area, if that makes it better, go another .95% reduction.
    62 Biscayne 425/409 SS/D stock class car 10.60s
    66 Dart 426CIG3 8.60@171 2750lbs Naturally asperated
    04 Ram All Alum , 468Ci G3 10.50s @4800 lbs Naturally asperated
    04 Rumble Bee, built 6.1 ,4000lbs 10.48 @ 129s MPH. Naturally asperated
    05 Rumble Stock 5.7, 3.92s TUNE ONLY 13.94@98mph
