Results 1 to 4 of 4
Thread: 6.0 Revslam
    6.0 Revslam
    Been playng with some stuff over the weekend, have it making somewhat decent power where i want it, but has started revslamming the 2-3 shift. I'm still on a stock trans tune as I have not ventured into that side of things yet. Was looking for some input if anyone had any. Ill attatch a copy of said file.
    2000 Single Cab Short Bed 7.3 400/200 476 two kits
    2003.5 2wd 6.0. 466k stock bolts. 170/0 and a bottle
    2006 CCSB Built engine 363 t4 swap odawgs stage 2 190/0
    Banned
    Jan 2020
    Arlington WA
    250
    why is your cutoff at 4750? and what type of power is this thing making because from the looks of this file your not make much at all. timing, icp, pedal map, everything really needs to be bumped up if your trying to make power.
    6.0s heavily depend on PCM side torque tables for the TCM logic.. make sure they’re mint, if not you’ll run into random issues.
    2008 J2 F-350 CCSB
    Trying to get a grasp of things a price at a time. I?m new to tuning and not trying to overload the plate. Figured if I can make small adjustments and work my way up, be better than loading the cannon and doing too much.
