Results 1 to 6 of 6
Thread: Sched. Maintenance Light issue before tune
    Dec 2005
    Pinch, WV
    198
    2020 RR has a scheduled maintenance light on, that will not go off after multiple attempts. Called the dealer, and they said to bring it in the computer just needed flashed.
    I just found this out when he dropped the buggy off to be tuned.
    Should I take it to the dealer first?, or go ahead and start the tuning process by connecting and Read and Write to the HPT provided file to the buggy?
    This is my first HPT/UTV tune, been using HPT since 2005.
    06 LQ4 2500HD CC LB 4wd 4.56, Dana 60,
    17 3500HD 6.0 srw
    GenIII Unlimited GM Full Size Truck/SUV
    Serial cable to WiFi
    Jul 2017
    529
    Are you trying to reset with BUDS? Or HPT?
    The ecu doesn't need to be flashed to clear maintenance soon message.
    But if there's a reflash update from the dealer, get that first, as whatevers on the ecu currently will be overwritten in a dealer update flash.
    Then, pull the tune (not actually pull, it's a virtual read) and tune from there.
    Dec 2005
    Pinch, WV
    198
    I didnt wanna try to read the buggy with HPT and the maintainence light on. But the light wouldn't clear by manually (override n brake method). So my neighbor brought "BUDS" home from work last night and got it all updated!!! Now I can begin my 1st CanAm gig!!
    Dec 2005
    Pinch, WV
    198
    First Can Am read, applied patch, save and write entire Success!!
    17 3500HD 6.0 srw
    Jul 2017
    529
    Quote Originally Posted by blucreek View Post
    It wouldn't matter, as you aren't "reading" the ecu.
    Dec 2005
    Pinch, WV
    198
    Correct!! There's always a first time for everything!! Thanks for the info.
    Im almost ready to go log Stock to make sure I have the right channels seleted in the Scanner.
    17 3500HD 6.0 srw
