Results 1 to 7 of 7
Thread: Fiesta ST Desired Lambda
    Feb 2023
    2
    Hi I have a problem tuning a Fiesta ST the desired lambda is going to lambda one when heavy load is applied while tuning on the dyno.
    I have tried adjusting desired lambda down but no matter what is populated in calibration it always targets lambda 1 on heavy load.
    Has anyone come across this before ?
    I have attached current cal file
    When it's WOT lambda enrichment enabled? It's normally set at 90% pedal as it will target stoich when below this pedal position. What lambda are you asking for in the WOT power enrichment?
    Feb 2023
    2
    Quote Originally Posted by CFGBR95 View Post
    I have rescaled enrichment so at 65 it?s targeting 0.81 lambda I have even tried targeting low loads richer but soon as it hit high load it targets lambda 1
    Dec 2011
    San Antonio, TX
    319
    Post your log. Desired lambda will move to give you the target fueling, just how the logic works. Sounds like its fat and needs leaned out some so the closed look isn't doing the heavy lifting.
    JTC Performance - Authorized HP Tuners Reseller
    Remote performance tuning
    There is a limiter that forced enleanment to reduce torque that is time based on some of the Ecoboost stuff. I had this issue with my '13 3.5, but I can't remember exactly what the parameter is.
    Owner/Tuner@Evolution Automotive Performance
    Lincoln, Ne
    Jan 2015
    565
    trans truncation can do this as well as part throttle load limiter. Post a log of the issue
    Dec 2017
    767
    what did it make on dyno
