Was just reading in the v8 section about some of this. I got a little confused there. I think their tables must be different from ours? In one comment the table gets maxed @ 96% from about 320 and up. The most they will see is 400 usually. Now, with a V6 that hits 225(in the scanner) would I not set mine to 96% @ about 170 and carry that 96% to the end of the table? Now, mind you, the table goes to 640, which is nuts, because I will "NEVER" see more than 250.
Any input guys?
I don't have any values below 300 @ 96% if that helps
