Hello,
I'm struggling to get my idle to return to normal after a throttle input. The 07 C6 Z06 starts up, and falls idle the desired idle. However, once the throttle is pressed, the idle never comes back down. Any ideas?
Scan and tune attached
Hello,
Mods?
It helps to know if your expectations are unrealistic for one thing.
The more information about the vehicle the better to help determine the fix.
Your injectors data are not stock. I attached a channel config file load it on your scanner and do a log. If you have a stock tune file post it.
test.Channels.xml
For posterity's sake:
The problem wasn't the idle itself. As mentioned in the initial post, the engine idled correctly after being started. The problem occurred when the engine speed was raised (goosed throttle). My solution was to remove air at problematic RPM ranges (1000 - 1600) in the Idle -> Airflow -> Airflow Final Minimum table. Now the engine smoothly comes back down to its target idle.
I am pleased to hear you got it fixed by removing air from the base running airflow, I would recommend you check out your idle settings too. Your minimum idle settings are actually above your base idle settings, this could cause the computer confusion wanting to pull down to your base set idle, but not being able to because your minimum idle is higher than your base idle. Good luck from one C6Z to another
