is there any way to change the tooth count for the trigger wheel for mod motor pcms?
i have an 05 f150 5.4, and i have the idiotic idea of ls swapping it with a gm gen 3/4 engine, but then running it entirely on the stock pcm with a few stock parts like the throttle and maf to further simplify the hardware side of the swap. very dumb, but still (probably) not out of the realm of possibility. other than vvt/afm/other complicated stuff like that i would delete anyway, basic things like trigger wheel tooth count would be an issue, and i dont know where to even begin with the cam signal. i guess i could have a custom 35x (or 36-1, whatever nomenclature) wheel made that wouldnt be too expensive or figure out how to mount a universal one, but i would just much rather change it in software if possible. also its going to be stick shift so tranny control is a non issue.
