Please help troubleshoot. My truck goes lean when in PE mode. It seems to always happen at 4000 rpm, it's like a step transition. You can see where I'm asking for ~.85 lambda and fueling accordingly then all of a sudden fueling changes to ~1.06 lambda. I see about a 10 psi drop in fuel pressure about the same time. I've been reading the forum and thought disabling desoot mode was going to be the answer but it did not help. This also happened when using my MAF tuning calibration. The truck is a 2011 silverado 4.8 swapped to a 6.0, high compression pistons, cam 283/286 lift .585/.585 LSA 112, VVT delete, stock headers with cats, truck manifold with 50# injectors (12613412), 6L90. Check out my log at 7:15:16. Thanks!
