Results 1 to 10 of 10
Thread: "OL-Not Ready" with EQ Cmd 15.97. Why and from where...
    Sep 2019
    43
    LS7 with TSP 4.2 cam, LT Headers, etc.
    While under very light load, < 2700 rpm, the car gets stuck in OL-Not Ready Fuel system status until coming to a full idle, or giving enough throttle to kick into CL or OL Accel.
    So something is triggering OL-Not Ready in these conditions, but can't see the trigger.
    And, when in this OL status, where is 15.97 AFR coming from? Car is full warm, and seemingly only after a little bit of cruise at very light throttle. It will continue until there is enough throttle to kick it back into CL.
    Note, in this datalog, it shows OL-Not Ready with mostly 15.97, but a few that show 13.60.
    So, Why OL under these conditions, and Where is this EQ Cmd coming from?
    Many thx!
    2006 ZO6 HCI V9 Posted Tune.hpt2006 ZO6 HCI V9 Posted DL.hpl
    13,565
    Because the cat test is still active in the exhaust tab. You need to turn those off or have someone do it for you if you are using too new of software.
    Sep 2019
    43
    Sounds good, but I only see Oxygen Sensor Thresholds for Lean/Rich for Upstream and Downstream O2s in the Diag Exhaust tab. To these need different mV values or is this OS missing parameters?
    13,565
    What version of software do you have?
    Anything after like 4.8 removed lots of features for many calibrations because of reasons.....
    Sep 2019
    43
    Yeah, this was all actually still with a 4.8.x... So it looks like the tables are just missing from this particular 2006 C6Z OS (though later model C6Z models are missing these too...)
    Any work-arounds if the usual tables are missing?
    13,565
    They aren't missing on my screen, when I open the files they are there for me.
    Sep 2019
    43
    Well dang, the plot thickens... I confirmed that this was viewed with 4.11.938 Beta which has been pretty trusty for a while now.
    Is there some user error on my end that might hide certain parameters? Am in Advanced. I even searched in Navigator for Catalyst and Test, and bupkus...
    13,565
    Like I said, if you are viewing the file with basically anything newer than 4.8, you can not see those tables. They removed them and you will require someone else to alter your file for you.
    I still have a MPVI 1 and someone with a MPVI2 can edit your file without a license, the original MPVI doesn't allow me to do that.
    Sep 2019
    43
    10-4, many thx!
    Sep 2019
    43
    Eureka! I found an old Editor version, and those tables are there... Thx again.
