Page 1 of 3 123 LastLast
Results 1 to 20 of 42
Thread: Installation of VCM Suite Issue
    Oct 2008
    28
    I bought a new laptop and am trying to download VCM Suite on my new laptop and keep running into the same issue. I get the following error message. Screenshot (44).png
    Any idea what's going on or what I have to do to be able to download?
    Oct 2008
    28
    Any ideas? Could it be a problem with Windows 11?
    Looks like your userid doesn't have write access to the required directory. Did you set up a userid that you're using that doesn't have admin access?
    Oct 2008
    28
    Quote Originally Posted by OhTwo View Post
    Nope, I only have one user ID on my laptop. I tried right clicking the download to hit run as administrator but that doesn't even come up as an option.
    Oct 2008
    28
    Spent the last 2 hours googling solutions and tried everything. Nothing has worked
    A couple of things... I don't think Windows offers an Admin install option for a .msi file which is how the normal install files are sent.
    (1) Not sure you can install anything so this may not apply but I've never used "Windows 11 S Mode" - if you're in S Mode, you'll probably need to get in regular mode.
    (2) Can you see that directory and if there's anything in it?
    (3) One issue that will cause problems is if something else is using that directory like another install going at the same time or if you have VCM scanner or editor open.
    (4) Try rebooting your laptop if you haven't already.
    (5.a) Open the Windows run dialog box: WINKEY + R
    (5.b) Unregister Windows Installer Module (type in run dialog box): msiexec /unregister
    (5.c) Re-register Windows Installer Module (type in run dialog box): msiexec /regserver
    (5.d) Reboot and try installation again.
    (6) If none of the above fix it, you may need to take ownership of the directory. I do this by right clicking the directory in file explorer (may need to do this to parent directory) and selecting "Properties". Select the "Security" tab and then "Advanced" button. From there you can "Change Permissions" or near the top of the dialog box, select "Change" next to Owner and change to yourself, hit "Apply", then probably reboot but the reboot may not be necessary.
    Good luck!
    Oct 2008
    28
    Thank you for taking the time to help, I appreciate it.
    Tried all of that and then some. Nothing I do seems to work, I keep getting the same message.
    Let me think some more and see if I can come up with something that's really helpful.
    Have you tried to install anything else - even the latest HP Tuners Beta? I know that goes to a different directory so maybe a good test.
    Anything installed can be deleted.
    Brain just popped as I typed - can you delete the directory in question and start installation over (maybe after a reboot)?
    If the laptop has an ARM processor, that could be a problem. They are not supported.
    https://www.hptuners.com/help/VCM-Su...ghlight=ARM%20
    Oct 2008
    28
    I installed AutoCAD a few days prior with no issues.
    I tried that also. Tried deleting, tried saving to a variety of different places, I get the same error message every time.
    Quote Originally Posted by crankz1 View Post
    I have an intel processor i-7 processor.
    Aug 2016
    386
    I had troubles with loading apps on a new laptop, I had to disable S mode.
    https://support.microsoft.com/en-us/...f-031bfb28a307
    1,489
    Have you tried a support ticket with HPT?
    Oct 2008
    28
    Quote Originally Posted by tunerpro View Post
    Just tried it, I keep getting a message stating I am unable to switch out of S mode on this version of Microsoft store.
    Oct 2008
    28
    I did, they've been trying to help me for a while as well
    Sep 2002
    Chicago, IL
    6,395
    If your computer is stuck in "S mode", i don't believe you'll be able to install any apps outside of the Microsoft STore.
    We got this guy Not Sure, ...
    Oct 2008
    28
    Quote Originally Posted by Keith@HPTuners View Post
    Got it off, still won't work
    Oct 2008
    28
    Beta won't work either; I get the same error message.
    Oct 2008
    28
    I gave up, I had to dig out my old laptop to use hptuners.
    One more thought is to do a fresh install of Windows 11 making sure you're not installing in "S" mode. Rare but I've seen install issues during my career that a fresh install has fixed. They were usually brought on by some weird issue during the original installation.
    Oct 2008
    28
    Okay I’ll give it that a shot when I get home.
