Results 1 to 5 of 5
Thread: 2015 Mustang ETC Torque request won't go above 738 lbs ft
    Aug 2015
    San Antonio, TX
    179
    Trying to get my driver demand ETC torque request to go above 738 lbs ft, but no matter what I have in my driver demand tables, it won't go higher.
    Trying to get a tune to work at 20 psi of boost but as soon as Engine Break Torque goes above ETC Torque I get the usual torque cut from timing and fuel. I have my DD table all the way up at 1,000 lbs ft, but the ETC request maxes out at 738 lbs ft.
    Only way I can get 20psi to run right is turn CLIP/ADD off, but then I lose part throttle feedback control that the CLIP system gives
    See the DD table and a log extractScreen Shot 2023-03-08 at 6.47.08 PM.pngScreen Shot 2023-03-08 at 6.53.12 PM.png
    Jun 2020
    788
    What’s your max map above Bp curve look like?
    Aug 2015
    San Antonio, TX
    179
    Got it set up like this. Hopefully that works
    Jun 2020
    788
    That can limit the torque request. I’d try raising it to see if that’s what’s limiting it. 738 sounds like a hard limit in the programming though. I can think of one workaround…
    Aug 2015
    San Antonio, TX
    179
    Yeah, I'll raise BP levels and see what happens.
    My workaround that I'll also test is in the Torque Tables I'm going to limit the torque to what seems to be the max like the table attached
