Page 3 of 3 FirstFirst 123
Results 41 to 43 of 43
Thread: Configuration & Histogram Repository
  1. #41
    Dec 2008
    4
    Hello,
    I am looking for a configuration file for the following:
    2005
    GMC
    Sierra 2500HD
    Engine: LLY
    Allison 5 speed Trans
    VIN: 1GTHK23215F888770
    I need the configuration file mainly for monitoring/ troubleshooting.
    I would like to have the dashboard display ECT, TPS, RPM, OIL PRESSURE, TRANS TEMP, MAP, IAT, SPEED, TURBO VANE POSITION (most important).
    I would also like to have all those parameters show in the chart display.
    Currently I have an oil gauge showing in the gauge display, but it gives no reading (needle is absent). I also can not figure out how to add a gauge for vane position or transmission temp.
    If anyone could give me a config file that already has these parameters that would be awesome. Or, even just specific instructions on how to add them myself it would be much appreciated.
    As a side note, If there is a way to see what the commanded vane position is versus "actual" (sensor reading) that would be helpful.
    Thank you For any help,
    -Dan
  2. #42
    Sorry Wrong thread - edited
    09 Pontiac G8GT LSA conversion & cammed (HP Tuned)
    07 Trailblazer SS Cammed & Nitrous Fed (HP Tuned)
  3. #43
    May 2015
    45
    SO 3 years and nothing from no one? I have the 06 lbz mut. lbz motor with lly tune from factory will be looking to switch to stock lbz tune before i even think about anything. However nothing? no simple diesel config that functions like a dash with coolant temp.,boost, egt, speed, tach, trans. temp the things you would like to just watch on a diesel. REALLY? Also can we get a sticky on this?
