Page 1 of 3 123 LastLast
Results 1 to 20 of 43
Thread: Configuration & Histogram Repository
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,266
    Aight guys as many of you have already noticed LS1's are the default when it comes to the config files & histograms for the most part. Here you can post what configs have helped you along. Include in your post with this format:
    Year
    Make
    Model
    Engine: LLY, LB7, LBZ or LMM
    OS: Engine & Transmission
    Vin
    What the config is for? MAF tuning, General, etc.
    If your post is missing anyone of those it will likely be deleted since I need that info to verify its a working configuration.
    If you have custom histograms you'd like to post as well feel free. Same info is needed.
    NOTE: Do not open the .cfg or .hst files with anything but the scanner.
    The .cfg (configuration files) go in your:
    C:\Program Files\HP Tuners\VCMSuite2 Directory
    The .hst (histogram files) go in your:
    C:\Program Files\HP Tuners\VCMSuite2\Histograms Directory
    Does anyone have a good LBZ histogram to share?
    HP Tuners Support
    (foff667)
    28,266
    Creating a histogram all relys on what you want OUT of the histogram.
    Asking, "does anyone have a good histogram" is like asking "does anyone have a good excel program" a good excel program for what? A monthly expense report or something to calculate how many home runs Barry Bonds hit on average in July for the last 10 years of his career.
    Without knowing what YOU want makes it IMPOSSIBLE for others to know what you NEED.
    Yea...that was kinda basic. Ok...let me re-phrase. I have the turbo vane position and EGR %, etc. However, is there a way to get the MAF or EGTs? And tranny temp as well.
    HP Tuners Support
    (foff667)
    28,266
    is there a way to get the maf or egt's to do what?
    again, to do what?
    Jun 2006
    eastexas
    104
    Dosent all ally equipt diesels come with a trans temp guage in the cluster?
    Quote Originally Posted by blued turboed1
    They do but just because its a gauge doesn't mean its right. My 2002 ECSB shows 74mph on the gauge but the HP Tuner's scanner shows 72 mph so...there is some error there.
    Quote Originally Posted by Bill@HPTuners
    again, to do what?
    I would just like to scan the EGTs at that time in place....it could be by rpms, tps%, or a combination of both. And for the MAF, I don't really know b/c diesels don't have LTFTs from what I understand so would you do it based on boost, etc to get the MAF the correct measurements.
    Tranny temp I would just like to log in the chart to see what the actual temp is compared to the gauge.
    Also, can you log boost(psi) vs. rpm?
    HP Tuners Support
    (foff667)
    28,266
    post a scan logging tps, rpm, maf, boost & egt and I should be able to create something for you.
    May 2007
    307
    is EGT a factory PID?
    is there no diesel config files at all?
    Dec 2007
    slc ut
    9
    this is what i have been scanning with the for general tuning
    i'll also post a log file from my tow tune.
    2001 lb7
    vcm o.s. 15188873
    tcm o.s. 15175854
    vin 1GCHK29191E337307
    Dec 2007
    slc ut
    9
    here is a quick scan i ran today of my race tune to check if my truck was holding enough rail pressure not very long but
    Dec 2007
    slc ut
    9
    i also made a few tweaks to the conf. of the pids i was using before there was a few bi knew needed to be added
    HP Tuners Support
    (foff667)
    28,266
    Very cool!
    Thanks Trentnell
    Jun 2008
    Lex Vegas, KY
    18
    Anyone have a good cfg for LMM's?
    Jun 2006
    eastexas
    104
    I dont know if it works or how well. Just finnished.
    Attachment 13383
    Advanced Tuner CRASHNBURN's Avatar
    Jun 2007
    Mn
    240
    Bill,
    Have you had any progress on some standard diesel pid so new guys can just start out & go? Any word on RTT or a switchable tune for the LBZ'S Chevys?
    Did you guys figure out how to do Tran slip yet?? Just this one would be great for now....Thanks.
    2006 LBZ Duramax 4x4 CC SB 2500HD SRW 4x4 LT1 (with extras), Blocked & Fingered, Fumoto drain valve, Keystone Ram Air Good Hood, Banks Ram Air, Access cover & Rhino over the rails, Victory Red.
    33'-0" Dutchman fifthwheel,Tekonsha Voyager Brake Controller
    Banks Sixgun with HPTUNERS.
    Jun 2006
    eastexas
    104
    Bill, I cant get turbo vane poss. to work. What am i doing wrong? I also am having issues loging IPW and Pilot fuel quanity.
    Chris
    Jun 2006
    eastexas
    104
    vin 1gchk29d96e260620
    os 12606128
    tcmos 15827766
    chevy silverado 2006 LBZ
    wanting to do general tunning,maf, IPW, fuel quanity,main timing , pilot timing, turbo vane possition. doing some upgrades in the near future. fleese turbo, trans, and converter.
    Attachment 13391
    thanks
    chris
    Feb 2006
    41
    Any New Configs?
