Results 1 to 14 of 14
Thread: Lq4 supercharged tune
    Jul 2018
    16
    Hello from cold Russia! I have a silverado 2000 2500 LQ4. My friend gave me a magnusson 1700. I installed it on the car, now I need to tune. Engine stock. 44lb injectors. help friends.
    Tuning Addict
    Jan 2015
    6,798
    You'll need to start by inputting the correct injector data and pull about 5 degrees of timing from .6 airmass and up. Dial in fueling then timing.
    ~Greg Huggins~
    Jul 2018
    16
    Do I need to upgrade to a 2bar os for 7-8psi boost?
    Mar 2011
    Ripley, MS
    1,865
    Quote Originally Posted by promobass View Post
    I recommend that you upgrade to a 2 bar MAP sensor and a 2 bar OS. It's certainly an advantage to allow the computer to change target AF ratio based on boost level.
    Jul 2018
    16
    do i need to use the original maf sensor or the increased performance? Or even turn it off?
    Jul 2018
    16
    Nov 2017
    1,461
    Your previous question isn’t really clear.
    Jul 2018
    16
    Do I need to use maf lq4 or, for example, l92 maf?
    Most boosted vehicles are tuned In speed density without a MAF. In some occasions i believe there is some that have MAF but they are running very little boost.
    Nov 2017
    1,461
    Whether to tune with or without the MAF is a larger question I'm not qualified to answer. But I don't think it matters which MAF you use, it just needs to be scaled correctly. I would stick with the one that is stock with your ECM.
    Jul 2018
    16
    how to correctly complete this table with 42lb injectors 17113739? Do I need a fuel pressure vacuum control line?Безымянный.jpg
    Tuning Addict
    Jan 2015
    6,798
    The g/s symbol - click on it and change it to lb/hr. Also you REALLY REALLY need all of the injector data for it to be right. Otherwise you'll chase your tail a lot. 42lb doesn't sound right if that's what came with the blower. Would think they would be bigger?
    ~Greg Huggins~
    Dec 2019
    MS
    567
    I remember the early days of the mp112 blowers for the trucks they only come with the 8.1 marine injectors.
    Jul 2018
    16
    I checked them by number and tested them on the injector test stand. they are 42lb.
