Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 70
Thread: Ls3/6L80E Swap Help please
  1. #21
    Mar 2023
    39
    fair enough, dont know if this will help
  2. #22
  3. #23
    Mar 2023
    39
    So on the X50a diagram underhood X3
    pin 1,2,3,9,14,16,19 and 50 were wired with switched key on power
    Pin 13 was wired to ground
    pin 27 was wired full power
    On X102 diagram
    Pin 2, 3, 4,5 6, and 7 are wired for the gas pedal(which was the gas pedal from the camaro)
    pin 9 mil control
    pin 1 was to full power
    pin 22 was wired to switched ignition power
    Pin 34 and 35 were wired to the OBD2 diagnostic port
  4. #24
    Mar 2023
    39
    again I'm not sure if this helps or if this is deeper than everyone normally dives into this stuff, but i appreciate the help and if its to deep just let me know
  5. #25
    7,646
    If nothing to do with the starter is being controlled through the ECM then ALL the starter junk in all the various places in the tune need to be turned off. On the 'OS' tab. And the System tab. DTCs too.
  6. #26
    Mar 2023
    39
    So i have everything in the OS and DTC turned of/disabled, as for in the system....on the "starter relay" I cant disable, I can either go low side or high side...and i have "starter Diag" disabled.
  7. #27
    Mar 2023
    39
    and in the DTC I turn of P1682 Driver 5 line 2??
  8. #28
    7,646
    I don't know, you built the thing! Are you using a powertrain relay like the Camaro did??
  9. #29
    7,646
    Make sure DTCs are set to No Error Reported; some are set to No MIL Light as stock, that is not the same thing. You want it to not even run tests on things that are no longer there.
    P0513
    P0615
    P0633
    P1629
    P1630
    P1631
    P1632
    And any U codes for modules that didn't get used.
    There are a bunch of DOD codes that need disabling. Don't forget the brake booster vacuum sensor codes - those are DOD also.
  10. #30
    Mar 2023
    39
    I appreciate your help and patients.
  11. #31
    Mar 2023
    39
    Because I'm not using the BCM do i turn off U0073(control module communication Bus A off)...I am still using the TCM
  12. #32
    Mar 2023
    39
    when you say DOD you mean Dtc error mode correct?
  13. #33
    7,646
    I assume you don't want DOD active, and/or have removed the failure-prone DOD parts from the engine?
    What about VVT?
    Don't disable U codes unless it's for a module that's no longer there. General Class2 stuff still needs to be functional, or at least won't cause issues if it's still there and being monitored for faults. Not even sure if disabling the codes would turn off Class2 anyhow.
  14. #34
    Nov 2017
    1,464
    The online descriptions for U0073 sounds like it might be at least part of your problem since it indicates a possible problem with the CAN network. I can check the 2010 Camaro service manual this evening to see what it says.
    Some of the online stuff for P1682 indicates that it is seeing different voltage for the portion of the ECM that controls the TAC vs everything else. This also sounds like something that might be a problem since I would assume both are tied to the battery voltage. Again I can check the manual when I get home.
  15. #35
  16. #36
    Mar 2023
    39
    I only removed the rear o2's from the motor and the evap solenoid. I didn't realize it had cylinder shut down on it! VVT is still wired in....should i be taking it out and disabling it?
  17. #37
    Mar 2023
    39
    Awesome, I'm going to check that now
  18. #38
    Nov 2017
    1,464
    VVT helps with the low end torque but will limit cam size. The DOD lifters have been problematic but I haven't removed them from my Camaro, just turned off in the tune. Whether I removed the DOD system would depend on the mileage of the motor. Fairly low miles I would probably leave it alone and turn it off in the tune. Higher mileage, I would probably remove it, or at least replace the lifters with new DOD ones.
    I would keep the VVT either way.
  19. #39
    7,646
    Cam & lifters have to be changed at the same time, the DOD lobes have really long lash ramps that'll cause misfires at idle if you put a standard non-DOD lifter on them. The DOD lifters have internal lash in the collapsible section, they need special lobes to compensate. The lobes on the non-DOD cylinders have conventional hydraulic roller lash ramps.
  20. #40
    Mar 2023
    39
    So for now, can i just turn off the DOD in the tune? then later on do a cam and lifters?
