Results 1 to 9 of 9
Thread: MAF Tuning question???
    Aug 2020
    4
    Unhappy MAF Tuning question???
    In hpt,under MAF Calibration;
    messured Mass Airflow in hpl;
    messured LTFT in hpl;
    Why MAF Calibration multiply messured LTFT not same with messured Mass Airflow?
    Nov 2017
    1,464
    What are you trying to tune?
    For the LNF ecotec you use STFT.
    Aug 2020
    4
    I'm tuning 2017 ATSL (LTG Turbcharge)
    Nov 2017
    1,464
    I'm not sure I'm following your question.
    What are you using to measure Mass Air Flow? Why doesn't measured MAF not match your input MAF since you are telling it how much airflow is there based upon the Frequency it's reading?
    Aug 2020
    4
    I use channel:Mass Airflow(SAE) as measure Mass Air Flow.
    By this channel,I measured the Mass Airflow number as below,
    But In my hpt file,
    the input MAF different with Measured MAF,this confused me. In my understanding, they should be similar.
    Nov 2017
    1,464
    I don't know anything about your ECM but a couple of possibilities.
    I'm not sure what your filter is doing. Maybe it's filtering out a lot of your data and throwing the average off?
    Sometimes the sensor/SAE channel isn't the one to use. Maybe see if you have any other options and not use the generic sensor.
    I don't know of any other way to "measure" the airflow other than MAF frequency. Maybe that "airflow" is calculated from the VE and that needs a lot of work. Is this a mostly stock vehicle?
    Aug 2020
    4
    when i get rid of fliter,no effect on my result.
    Maybe that "airflow" is calculated from the VE and that needs a lot of work. ----- (It seems reasonable)
    my car is cadillac atsl
    Jan 2014
    Australia
    1,982
    how are u adjusting the MAF ? u cant use mass airflow g/s against the hz of the maf to correct it, if im seeing what ur trying to do right ? u need to use a wideband to do the OL areas or u can use the trims for the CL areas to get the fueling closer to commanded which gets airflow closer
