Results 1 to 10 of 10
Thread: 6.7 powerstroke vgt table missing
    Banned
    Jan 2020
    Arlington WA
    250
    is there a reason why hpt is missing the vgt tables?? does anyone else see them?? SCT has them but HPtuners doesnt.. this is 2017-19 file.
    Jun 2018
    Albuquerque New Mexico
    467
    Vane map.pngThis is Beta 5.1.324
    Banned
    Jan 2020
    Arlington WA
    250
    That looks right, labeled different. Im also curious why they both dont have ebp pressure set points even though the truck uses ebp. ebp should have some control on the turbo side of things. I modified that to make a HISS tune and it didnt do anything. im trying to get the vgt to 100% at idle and that didnt work. also modifed boost pressure base setpoint and still nothing.
    Jun 2018
    467
    Where did you modify it? Log current torque and see where it's at during idle, should be between 0-110ftlbs or 0-150NM. They are the same tables just axis are inverted and in Ft lbs instead of NM
    Sep 2021
    34
    Did you try modifying mode 3 tables?
    Banned
    Jan 2020
    Arlington WA
    250
    i tried modifying all the boost pressure set points, boost control set points, every map tables, and vgt tables. put them all to the max from 500-1000 rpm.. truck still rumbles at idle.
    Banned
    Jan 2020
    Arlington WA
    250
    Jun 2018
    467
    Quote Originally Posted by Powerstrokecustoms View Post
    Yeah that'll do it! I assumed you'd changed it already and was like what else could it be lol. Glad it's working for ya!
    Banned
    Jan 2020
    Arlington WA
    250
    the crappy part is, in sct they have boost pressure control upper limit and lower limit. and its under diesel boost control threshold. and its labeled as a upper limit PCR controller. I was like come on. i do way more tuning with SCT then HPT just because 1. there's just way more stuff to modify and 2. you can save the mods you do to a specific table as a value file.
    Feb 2024
    Has anyone figured out how to adjust this more adequately, recently installed a no limit fab 64/67 turbo on my 22, reset vgt and have had issues during certain driving conditions. I have logs that can be provided if anyone wants to help me tackle this concern. I know it has something to do with the VGT tables that are currently on the tune as they are set for the smaller size turbo.
