Results 1 to 5 of 5
Thread: Jeep Wrangler 3.6 Unlimited Sahara
    Apr 2016
    30
    Hello to all
    I have a customer with a Jeep Wrangler 3.6 unlimited sahara 2017. This guy installed a lot of goodies on the car including a Supercharger.
    this customer got the ecu to a local tuner (not Hp tuner) to tune the ecu for the supercharger with a disaster results, broken engine.
    then got the car to other tuner, that used K-tag to tune the ecu...so the car is not runing well as these tuners doesnt understand that a supercharger mod needs a lot of tuning, logging and edit a lot of tables to be ok.
    Finally this cusomer came to me, and i requested to get the ecu stock to flash with HP tuners. they did it but through the ODB, so the patch on the software from Alientech is still there and when i try to flash the HP tuner map, i couldnt. I can read the "stock" map, and the customer got me the "OEM" map read by the previous tuner from ecu.
    Is there anyone that could get this ecu and get to stock from by "boot" to clear the patch on the software and let us tune by HP tuners?
    thanks
    Mar 2021
    Pompano Beach FL
    261
    I can, But you will need to ship me the PCM.
    www.n2speed.com
    http://www.amp4x4.com
    [email protected]
    Dodge And GM Tuning Suppport
    Diablosport CMR | HP Tuners
    Apr 2016
    30
    Quote Originally Posted by N2speed View Post
    Thanks for your reply.
    Sent the ecu will not be a problem. if i get you the "OEM " map, can you check if this has the Alientech patch on it? because if it has it , we will still have the same problem, or may be you have a stock map to flash on this ecu
    Please let me know
    Mar 2021
    Pompano Beach FL
    261
    Once I reflash it the patch will be wiped. And HP tuners will work again,
    www.n2speed.com
    [email protected]
