I've searched through the forums for 2 days but can't seem to find the information I'm looking for.
Why does the ecu have to pull timing out of the engine to lower power on shifts to protect the transmission vs just letting the power build like older carbed engines did. I have a junkyard th350 that gets abused alot and it shifts fine throughout the rpm range of the engine without breaking. Both my 6.0l and the old sbc that's in front of the th350 are in the same power and torque range.
I understood the factory does it on LS stuff because they need them to pass emissions and live till the warranty runs out. But everything I've read says if you turn torque management off where it's not pulling timing and everything out on the shifts it will break the 4l80e. Are they really weaker than my junkyard th350 and th400s dinosaurs?
And I'm sorry if this has been covered somewhere in another thread I just haven't had much luck with the search function actually finding an answer to my question. I've watched a bunch of videos but they don't say much about the comparison between how the older stuff holds up better to full timing and fuel all the time vs the newer stuff that has to be stepped down in between shifts to keep from grenading it.
