Hi all, have a stock 2015 Marine Power L96 6.0L controlled by a E78 ecm running MEFI 6 in a jet boat (E78 service number 12642442 1138). Being MEFI with wet exhaust it is open loop speed density but does have factory DBW throttle body. Runs fine but I want to do a cam upgrade and tune it. I don't know any cost effective way of editing MEFI 6, so I am thinking of getting another E78 flashed with the stock L96 truck tune, editing that to run SD OL on the bench, and swapping that in so I can use my HPT to tune the boat after I upgrade.
My questions are:
1. Can the standard truck tune E78 be edited to run properly in speed density and open loop without any limp mode and also without any TCM. The boat has no check engine light and only a tach so I don't care if I get fault codes as long as they don't interfere with engine operation and the tach output, oil pressure, water temp signals work.
2. My existing 3 harness connectors will plug right in but is it safe to assume that all the pins do the same thing - is the pinout generic to the E78 or does it change with the OS/Tune? It'd be great to just plug it in and go.
Thanks for your help.
Cheers, Andrew
