I am working on a tune for a friend for his mustang but we are having issues with getting a stable idle. Starting the car is fine then when the idle settles it can go even below 500rpms sometimes. Its not an all the time kind of thing but it can be duplicated by revving it and having the rpms fall. They do not see to be able to catch themselves. The kenne bell has the 168mm TB and I wanted to mention too that his trans has been swapped to a t56 magnum xl. The only things I have messed with are Enable RPM error and Disable RPM Error under Idle and General.
