Hi everyone,
I have a 1969 Firebird with a LS2 from a 2005 corvette (along with the cars pedal and E40 ECM) that is paired to a 4L60E that has been giving me nothing but trouble. My car is just about finished (25k paint, with almost $60k total into the car now) but I'm having a very weird issue. The issue I thought was from the transmission it-self but I was apparently wrong. The car will drive fine for about 20 mins and then it starts to bog down almost like something is applying the brakes and it gets progressively worse while at the same time the trans temp starts to shoot up which I have seen 250 degrees briefly just trying to get the car back home.
I rebuilt the 4L60E (came from a 2002 trans am) and still had the issue. So I thought I goofed something up on the rebuilt (I am a A&P with more than 20 years exp) and I tore the trans apart and put it back together a few times just double and triple checking everything. The same problem was still there after driving 20 or so mins. So then I bought a new level 2 Performabuilt 4L60E and put that in thinking that this was the ultimate fix, but again after 20 mins the damn problem was still there (talk about a $3k gut punch). So while I did get some of my faith restored knowing that the trans I rebuilt was probably just fine.
So I am trying to narrow down and find the root cause still. The last thing I tried was I purchased a VCX Nano and paired the TCM to the E40 since the T42 was the only item I wasn't able to get from the donor car. The T42 I purchased was also from a 2005 corvette A4, but just to ensure that the link between the ECM and TCM was good I got and paired the SPS programing on both to pair them. The issue was still there...
I am relatively new to HP Tuners but I am far from an expert, yet know enough to get around and understand most of it.
Below is a few things I have tried and as well as things I have checked.
- Pair the ECM to TCM with SPS programming
- Segment swap 05 GTO TCM settings since the setup is no longer a transaxle
- Raised the misfire tables by 20%
- No DTC's are or have been present Both ECM or TCM
- Verified VSS signal is accurate with GPS
- Removed all TCM TQ Management (Abuse as well)
- Turned off mil light and set to no error reported for the most common swap config settings
- disabled catylist settings
- Used BlueCat to setup gear and tire settings since I have a 2700 rpm stall.
I have attached the stock minus vats delete tune I have just in case anyone wanted to reference the current settings I have. I have thrown everything and the kitchen sink at this I believe so I hope someone can help me. I would even pay someone for their time if they could help fix this. The next thing I was contemplating next is buying a Holley Terminator Max (Another $1700) since I have a feeling the issue is being caused by the ECM but I don't want to buy another one unless someone on here can help me verify the one I have is bad.
I'm at the end of the road and I just don't know what else I can do. If a new engine management system does it then I would happily pay for it, but I don't want to do that if it won't it.
Sorry one last idea that crossed my mind is possibly geting a 05 GTO Vin and SPS program the ECM and TCM I have to a 2005 GTO with the A4 (if there is something that HP tuners can't change being there are 2 areas that HP tuners doesnt see or show.
