Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
Thread: Can the MAF be tuned without driving??
  1. #21
    Aug 2010
    Detroit, MI
    932
    Its done on a flow bench with the representative intake plumbing. Virtually every sensor or actuator is characterized independent of the vehicle.
  2. #22
    405
    2,326
    Quote Originally Posted by smokeshow View Post
    That is what I thought. Care to elaborate why when it is unmodified on that stock vehicle/location that it needs to be recalibrated? Or does it? Most seem to think it does. I'm sure the OEMs go through a lot of effort to characterize it. I'm asking because i know you were an OEM calibrator.
  3. #23
    Sep 2009
    764
    Quote Originally Posted by 2xLS1 View Post
    Typically it does not need to be altered. Hence why I run MAF only and dial in the VE tables by data logging the VEs on a running engine. I can get the VE tables very close using MAF data and a histogram.
  4. #24
    Feb 2021
    Houston, TX
    53
    Quote Originally Posted by Fast4.7 View Post
    Is there a "how to" posted on this method somewhere? That sounds interesting.
  5. #25
    Aug 2010
    Detroit, MI
    932
    I suppose it depends on a few things...age of the vehicle, engine/hardware health, what you consider enough error to justify recalibration, etc.
    Quote Originally Posted by Mingus View Post
    Yes, I wrote a thread on it. It incorporates fueling correction, so if you wanted to strip that out and populate VE from MAF only, remove the fuel trim part of the parameter.
  6. #26
    So, what's the highest Hz you can reach in neutral without the engine experiencing rapid unscheduled disassembly?
    lmao
