I will go ahead and list the details first. 05 5.3, ss2 cam/springs new lifters, filed rings .030, Ported 706 heads with Speedmaster intake, Single Gt 45, Deka 80's, inline external fuel pump and cell, running straight e85. I had some issues getting the car to start when i got done installing the engine, Flushed the fuel system, pump was stuck after sitting 3-4 months. Found a spreadsheet with the injector data and copied all that, running 07 p59 without a flex fuel sensor, used the VE table from an LS1 tune i did for a friend and that seemed to make it run fine. Car runs for a minute or less then just turns off, i was having an issue getting scanner to connect but its always a pain anyways. All of my sensors are showing a normal reading, i have good throttle response, the car will drive but just shuts off. I remember when i had this problem before i would start logging in VCM scanner and as soon as I start the car looking at the lt/st fuel trims it would highlight a cell it was in and start counting up from 1 to 999 and just shut off. I'm not sure if I ever pinpointed why but that is what it was doing and wont stay running long enough to get a good log as is. I am looking at this older log now it says the vehicle is a 2007 Chevrolet Silverado 5.3l V8. I can run a different PCM , I Have a bunch. Any ideas would be appreciated. Top file is the 03 PCM the lower one is the 07.
03 3 bar in volvo.bin
Volvo 5.3 Deka 80LB with Data.hpt
