Car is a 2004 C5 stock PCM running a GMPP LS376/525 Crate (LS3 w/ ASA Cam). Car is a dedicated track car, headers, drilled aluminum flywheel. Running the LS3 Gold blade (capped at 95% TPS). Car was dyno tuned and runs like a scalded ape. The issue is that the car drops off revs very quickly and stalls 50% of the time. I've tried RussK's idle tuning and some other parameters. It's improved 50%, mostly by adding base airflow and follower airflow. I have not adjusted any spark, VE or fuel from the original dyno tune; just airflow and follower airflow/delay. I'm hesitant to make any further changes as further airflow changes seem to have limited effect.
Please let me know if you have any further tips for a beginner!
-TWIG
