Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: DFCO Not Working At All
    Aug 2020
    Knoxville, TN
    84
    Hey all. I cannot figure out why my friend's Camaro will not enable DFCO on deceleration. I have messed with the cylair and throttle parameters because the car has a cam and supercharger on it. But not matter what I do, it won't enter DFCO. I attached the tune and a log for everyone to look at. Any help would be greatly aprpeciated.
    2023-03-28 Checkpoint.hpt
    23-03-26 11-37-35.hpl
    Oct 2019
    285
    Mine did this too. I turned off the LTFT Idle Cell Threshold VSS.
    Still not sure why it was doing it, but it fixed my issue.
    I'm not on my tuning laptop so I cant see your tune now.
    Aug 2020
    Knoxville, TN
    84
    Quote Originally Posted by marksrig View Post
    Did you just set the enable and disable VSS to 0 for this? Mine was at the stock values which enabled at 2.5 and disabled at 3.7 mph.
    Oct 2019
    285
    This is my current settings.
    ENGINE - FUEL - OXYGEN SENSORS - LTFT IDLE CELLS THRESHOLDS
    Enable TPS 0.0%
    Disable TPS 0.6%
    Enable VSS 255 MPH
    Disable VSS 256 MPH
    I'm curious if my idle trims will change over time but so far it just fixed my DFCO not working. Sometimes if the RPM's are lower, it'll only go to stoich, but not every time.
    Aug 2010
    Detroit, MI
    932
    DFCO entry spark is below your min spark. It cannot enable like that.
    Aug 2020
    Knoxville, TN
    84
    Enable TPS 0.0%
    Disable TPS 0.6%
    Enable VSS 255 MPH
    Disable VSS 256 MPH
    This would enable your LTFT idle cells at any speed so long as you're not on the throttle. I don't understand why this would enable DFCO.
    Aug 2020
    Knoxville, TN
    84
    Quote Originally Posted by smokeshow View Post
    I did the same on a friend's C6 and his just goes down to the minimum and enables. In this car I'm having issues with, it doesn't pull timing at all. It's not like it pulls down to the minimum but then doesn't enable DFCO because the DFCO entry is lower. It doesn't even ramp down when you're off the gas.
    Tuning Addict
    Jan 2015
    6,813
    Quote Originally Posted by M3T1 View Post
    The speed setting disables it.
    ~Greg Huggins~
    Tuning Addict
    Jan 2015
    6,813
    See how this one does for you.
    ~Greg Huggins~
    Advanced Tuner morepowerjoe's Avatar
    Sep 2021
    Austin
    292
    My dfco doesn't work either but all my settings are stock. I don't even know if the factory even meant for it to work in the first place. Since my engine it heavily modified does that change anything because like I was saying all my dfco settings are still set to stock shouldn't it be working somewhat or does it have something to do with the fact that I'm running a maf tune?
    Camaro Tune.hpt
    Camaro log.hpl
    L99 A6 - DSS FX Forged Piston's, Eagle ESP L19 Rods, ARP Head and Main Studs, LS9 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnion Upgrade, TSP Chrome Molly Pushrods, BTR .660 Valve Springs, GM Hollow Intake Valves, Melling 10355HV Oil Pump, IR EGM-205 Oil Pan Baffle, CAI Intake, Fast LSXR Intake Manifold, Nick Williams 103 TB, ZL1 Pump, TSP 1 7/8" Longtubes with 3" TSP Exhaust, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter
    Aug 2020
    Knoxville, TN
    84
    I'll give it a shot
    Aug 2020
    Knoxville, TN
    84
    No change. Same deal. Timing off-throttle goes to 20 degrees and just stays there. Doesn't ramp down at all, and doesn't enter DFCO.
    Tuning Addict
    Jan 2015
    6,813
    So it is working? Cause that's how I had it set up to go into DFCO. After passing 3000rpms it should have dropped to 15 then 10 by 2000ish. Post another log.
    ~Greg Huggins~
    Aug 2020
    Knoxville, TN
    84
    No. As I mentioned above, there was no change with the DFCO settings you recommended. I attached the log. As you can see, off-throttle the timing goes to around 20 degrees (which is close to the coastdown table value) and just stops. Doesn't ramp down to 10 and doesn't ever enter DFCO.
    23-04-06 19-40-28.hpl
    Oct 2019
    285
    Did you try mine? Wont hurt.
    Tuning Addict
    Jan 2015
    6,813
    OK, I see what you're saying. You're saying after adaptive idle spark control kicks in your left with 20 degrees of timing and it's not in DFCO.
    You might want to combine what marksig did with the corrections I made for a better chance of it working. It should be going in with those changes. I'll have to take another look later and see if anything else stands out.
    Did this start at any particular time or change made that would help point in the right direction?
    ~Greg Huggins~
    Aug 2020
    Knoxville, TN
    84
    I have not yet. I just sent him a new file with your suggestion to try. He's out of town until next week so he's gonna try it next week.
    Aug 2020
    Knoxville, TN
    84
    Right. I have never seen anything like this before myself.
    Unfortunately, it didn't start at any particular time. My friend just bought this car, and it has had this issue the entire time. I cleaned the tune up for him, and he says it runs awesome. This is the only issue remaining, and I cannot figure out why the hell it isn't working. It's meeting all the conditions but never entering DFCO.
    FWIW I have tuned a bunch of Gen 4 platform vehicles (and even more Gen 5 vehicles) and never had this issue with any of them. I'm going to try @marksrig's change. It doesn't make sense to me why it would work, but it can't hurt to try.
    Aug 2018
    20
    The enable TPS of .11 through most of the range looks to be too high, it has to be less than the set value to enable DFCO. In the log it looks like a closed throttle gives a value of 12.2% which is expected. In my '06 V I have set quite a bit more aggressive than the stock settings all around including the crank pulses so it goes into DFCO real fast and it's still smooth in transition and will DFCO right down to my 900rpm disable point.
    Aug 2018
    20
    Another table that affects this that isn't in the DFCO area - the BRAF settings in idle airflow (in gear values) can't be too high or it won't allow DFCO. If the value is too high it won't allow DFCO to enable.
    Also - ANOTHER one that messed with my DFCO was the speedo setting when I was trying to adjust for my larger rear tire to get my speedo in sync. When I adjusted the 'Dist' setting, which his is adjust way less than stock I believe - it adjusted my DFCO and it would not enable as before. Can't make sense of it but check it out! My 'Dist' value is 1245.78, same as stock on my car. FWIW that value does not adjust speedo on my car, I have a separate value for PCM pulses per mile.
    I'm not a pro and have only tuned my car but really enjoyed getting it dialed in and found these things out.
