Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
Thread: DFCO Not Working At All
  1. #21
    Advanced Tuner morepowerjoe's Avatar
    Sep 2021
    Austin
    292
    Quote Originally Posted by lowmpg View Post
    Another table that affects this that isn't in the DFCO area - the BRAF settings in idle airflow (in gear values) can't be too high or it won't allow DFCO. If the value is too high it won't allow DFCO to enable.
    Also - ANOTHER one that messed with my DFCO was the speedo setting when I was trying to adjust for my larger rear tire to get my speedo in sync. When I adjusted the 'Dist' setting, which his is adjust way less than stock I believe - it adjusted my DFCO and it would not enable as before. Can't make sense of it but check it out! My 'Dist' value is 1245.78, same as stock on my car. FWIW that value does not adjust speedo on my car, I have a separate value for PCM pulses per mile.
    I'm not a pro and have only tuned my car but really enjoyed getting it dialed in and found these things out.
    Good info sir.
  2. #22
    Aug 2018
    20
    Any luck?
  3. #23
    Aug 2010
    Detroit, MI
    935
    True story. If min idle air pushes TPS above the max throttle area allowed for idle, it is considered open throttle...so no fuel cut.
  4. #24
    Aug 2020
    Knoxville, TN
    85
    No such luck yet unfortunately :/
  5. #25
    Jul 2018
    DENVER CO
    20
    05.28.2023 80#.hptif it is a manual trans i came up with these settings to enter dfco quickly.
