Results 1 to 6 of 6
Thread: why Torque MGT pull Timing
    1971 Chevelle Stock Ls3 4l80e
    The car runs grat but sometimes pull Timing at Wot.
    In the Scan I see that the Torque MGT is active.
    I have taken out all known torque limits.
    You can see in the scan the first two Wot runs are good.
    Ane the last two pull timing but why?
    Thanks for Help
    Advanced Tuner morepowerjoe's Avatar
    Sep 2021
    Austin
    292
    I would think that it would be something to do with your torque reduction in the trans because it's still active 15417 / 15418.
    L99 A6 - DSS FX Forged Piston's, Eagle ESP L19 Rods, ARP Head and Main Studs, LS9 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnion Upgrade, TSP Chrome Molly Pushrods, BTR .660 Valve Springs, GM Hollow Intake Valves, Melling 10355HV Oil Pump, IR EGM-205 Oil Pan Baffle, CAI Intake, Fast LSXR Intake Manifold, Nick Williams 103 TB, ZL1 Pump, TSP 1 7/8" Longtubes with 3" TSP Exhaust, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter
    Oct 2014
    Moscow, Russia
    197
    Post log times when you think something wrong is happening.
    2011 Cadillac Escalade L94 w/LS3 valves and valve springs
    Okay I thought that he only reduces the shift torque
    @ 10,22 in the scan the Timing goes down to 4 degrees.
    and @ 11.16.
    thanks
    Oct 2014
    Moscow, Russia
    197
    Quote Originally Posted by speedjunction View Post
    and @ 11.16.
    thanks
    Those two cases is a downshift tq reduction (Table 15416)
    Thanks for your Help
    I have not senn That is make on the downshift.
