Thread: 2017 Ram 1500 R/T, 2.9L Whipple SC issues
    Sep 2022
    Tulsa, OK
    I had a Whipple SC installed last fall and it has never run correctly since the day I picked up from the shop / tuner.
    It flashed "Service Electronic Throttle" and went into limp mode 3 times on the home alone.
    It has a "stutter" at 2,000 RPMS just cruising 70MPH on the highway.
    It would cut-out badly at WOT and throw random misfire codes. (Another local mechanic figured this to be shots of oil coming from Mishimoto catch can, a Mighty Mouse mild catch can with built in PCV system is on the way to hopefully end this issue once and for all.
    The tuner sent me another tune revision last week and all issues are still present.
    He attributes it to the Whipple 102MM throttle body being bad, but I've asked him for evidence of that as Whipple says they need some evidence it is throttle body related.
    Then he says I have a fuel issue and need an upgraded fuel pump even thought my fuel pressure is always steady at 58-59 PSI and I've never seen it below 53PSI at WOT.
    The tuner is almost non-responsive to me now, and to be honest I just kind of want to move on from him and get a second opinion and let someone else dig into it.
    There are no tuners for MOPAR anywhere near Tulsa, OK to my knowledge.
    2017 Ram 1500 R/T 5.7L with 8-speed automatic
    SW long-tubes w/high-flow cats into SW true duals & chambered mufflers
    RIPP Mods high-performance coils
    Whipple 2.9L SC with 102MM throttle body & CAI
    Plugs provided by Whipple & gapped to .28
    58# injectors provided by Whipple
    TCM Tune 2 Tune 13.hpt3-21-23.hpl
    Mar 2021
    Pompano Beach FL
    264
    Can you send me a copy of your backup file and I will take a look
    [email protected]
    www.n2speed.com
    http://www.amp4x4.com
    [email protected]
    Dodge And GM Tuning Suppport
    Diablosport CMR | HP Tuners
    May 2021
    Quote Originally Posted by Eden14699 View Post
    I have the same setup in my 14? Durango & also have been experiencing similar problems to what you?ve mentioned. Were you able to get things sorted & can you recommend someone to help?
    5BA8
    3,253
    Quote Originally Posted by meoryan1 View Post
    Start your own thread and post your tune file and a data log. There are a few guys here qualified to help you out. Digging up a nearly year old thread is not the best procedure.
    email=[email protected]
