hello, i have a 411 pcm and am currently building a turbo 5.3 with a 76mm turbo. can someone help me with a basemap or point me in the direction so i can flash my pcm properly with the best os for this setup.
my setup is
02 5.3 out of a tahoe
decapped injectors (approx 80lb injectors)
7675mm turbo
4l60e transmission
gm 3bar map sensor
iat sensor welded to the charge pipe.
if you need more info please let me know and i will provide it.
another question i have is , is the stock 02 tahoe pcm the best pcm for this setup? is there a better pcm out there that i can purchase that will do the job better?
