Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
Thread: Long tube headers and mds 6.4 delete cam
  1. #21
    Jan 2022
    900
    thx. i know what the inside of the manifold looks like and see cyl 1 getting a advantage, maybe?
    "maybe", only cuz i know how much turbulence effects flow
    the article ^^^ is good but i no longer believe all that stuff. 20 years ago i was working with rick ward on a pro stock port for a hemi (a true hemi, not what we have now with this gen 3) and he suggested taking out the short side radius. i mean he wanted to epoxy the roof all up, make the roof flat instead of round, and hog the floor out, making it a straight shot to the seat. (and round instead of flat). i was like that will never work, everyone knows it wont flow if you hog out the short side radius. well, thats exactly what he did, flipped the whole port upside down really, and set a new national record.
    that made about as much sense as these fueling multipliers for bank 1 do
    *cyl 7 gets more fuel at 4000 than cyl 3 does. more at 5000 as well. If its packing the air at the rear than cyl 8 should not be 1.000
  2. #22
    Advanced Tuner rays04gtx's Avatar
    Oct 2021
    Allentown PA
    363
    Quote Originally Posted by LilSick View Post
    Yeap, Been there , Removing the short side on Hemi style heads started with the D5's in the 70s, this was head come off our 1120hp 431ci G2 hemi, circa 1998-99, No short side, you look down the intake port and all you see is back side of valve, .............also works WONDERS for the G3 head.
    62 Biscayne 425/409 SS/D stock class car 10.60s
    66 Dart 426CIG3 8.60@171 2750lbs Naturally asperated
    04 Ram All Alum , 468Ci G3 10.50s @4800 lbs Naturally asperated
    04 Rumble Bee, built 6.1 ,4000lbs 10.48 @ 129s MPH. Naturally asperated
    05 Rumble Stock 5.7, 3.92s TUNE ONLY 13.94@98mph
  3. #23
    Jan 2022
    900
    SAF
    bet no one cyl there was making 6% less than the one next to it : )
  4. #24
    Sep 2021
    Florida
    64
    well here is kinda the best 1, everything is +/- 1% on scanner except idle which is fat eights and 10's on 100+ degress days. gonna try to get another complete system readiness test done and well see wut it do with these big ass headers and cam
  5. #25
    Jan 2022
    900
    too bad you spent all that time on yer pe tables with the cam retarded like that
  6. #26
    Sep 2021
    Florida
    64
    pe tables are easy and dont really want to spend the time for tiny gain with cam that basically factory is little better than mds because of a small amount of valve movement even with gains there its really vvt angles advance timing that has more better gains. really be looking for that burn fraction inverse and lamba stuff with my free time.
