Never said it wouldn't work - said it would contradict what he's doing it for
The biggest struggle for any blown LS or LT is getting the exhaust out - whole reason when you get a cam the exhaust side usually has the most changes as far as duration and everything is involved. Talk to Brian some time. I've spent a couple of hours on the phone with him discussing what I've found to work vs what didn't work back when I was designing and building engine setups and he always pretty much agreed with my findings. Even said lift does make a whole lot of difference - it's all in how long you keep the valve open and when it's opened. Of course I don't remember all of the details of what we talked about as it was 5 or so yrs ago.
He can do it, but cylinder pressure and boost will both go up and it won't flow anywhere as good up top, but then again - who knows - maybe it'll respond well to the added boost.
Main differences for the lt5 and lt4 are cam, crank, rods and blower / take crank and rods out as they should be the same dimensions and then account for the lt5 running the 2650 most likely turning a lot slower - the cam could be used to get boost up in this scenario while still keeping things much happier.
Just to confirm that comment -
Displacing 2.65 liters, the LT5 produces 14 psi (0.9 bar) of boost. That's about 4.5 psi more than the LT4 engine, but achieved with a slower, 15,860-rpm maximum rotor speed, which helps keep down the pressurized air charge's temperature.
And then this for the lt4 stock -
Stock |
Blower Pulley Diameter |
2.505 |
Inches |
Lower Pulley Diameter |
7.75 |
Inches |
Pulley Ratio |
3.1 |
Ratio |
Blower Speed @ 6500 |
20110 |
RPM's |
^^^^ After seeing and understanding this, you should be able to understand why the lt5 was given the cam it got - plus it makes "emissions" a whole lot happier and the bigger blower happier turning slower while still making more power.
