Results 1 to 13 of 13
Thread: How to write a new TEHCM on a 2011 Silverado
    Feb 2023
    6
    Hey all,
    New to tuning and trying to figure out how to write a new TEHCM so I doin't have to take it to the dealer. Is there a video available to watch or just really good instructions?
    7,647
    I don't think you can, unless you have something that can use GM SPS. HP Tuners is not a J2534 passthru device.
    Feb 2023
    6
    I was told you could by copying the number off the old TEHCM unit and writing it on the new one. Just don't know what the procedure is.
    7,647
    Then go ask whoever told you that.
    Advanced Tuner Josue Galban's Avatar
    Jan 2023
    Venezuela
    205
    try it, maybe it's possible, look for that person who can help you
    405
    2,326
    You have to have read and saved (and licensed the corresponding ECM) the hpt file out of the old TECHM and write entire that file to the new (remanufactured) one. If you don't have that file then SPS is the only option
    Feb 2023
    6
    Quote Originally Posted by 2xLS1 View Post
    I just don?t know how to do that. I?ll see if I can figure it out. Thanks.
    Feb 2023
    6
    That?s no longer an option.
    13,565
    What isn't an option anymore?
    If you never had HP Tuners to read the file and licensed it before you replaced the TCM, then you are out of luck with HPT. A dealership or someone with the correct tool will have to flash the TCM for you.
    Feb 2023
    6
    Thanks for the reply.
    Jul 2010
    Illinois
    16
    so if i read the original trans before i removed it and installed the reman one. I should be able to write it to the new(reman) transmission and it be good to go?
    Mar 2017
    3
    I tried doing this recently on a 2013 Yukon Denali, I had the original file before the transmission went bad and tried to write it when I installed the new transmission and it wouldn't work. I had to use SPS, if there is a way I'd definitely like to know!!
    405
    2,326
    Quote Originally Posted by Jmeyer View Post
    Did you try write entire or write calibration?
