Page 1 of 2 12 LastLast
Results 1 to 20 of 37
Thread: LS3 & GM performance trans controler
    Jun 2018
    Franklin NC
    35
    Build has 2008 Vette LS3 and aftermarket performance transmission with GM performance 19302409 controller & harness. The Can lines have been connected between modules. The transmission module shows RPM, coolant temp, battery voltage. But doesn't show MPH. Has anyone found way get two to work together?
    ECM has vss sensor and shows input. But trans setting in the ecm has be (manual) for it to register. When set to auto the ecm vss doesn't register. Never registers in auto trans module.
    This setup is in 78 CJ7
    Jan 2014
    SoCal
    1,583
    https://d354nuoz4t18d4.cloudfront.ne...r-10302410.pdf
    Instructions show it needs a connection directly to the ECM from the OSS to get MPH
    Jun 2018
    Franklin NC
    35
    Quote Originally Posted by TheMechanic View Post
    This is what I see in the instructions.
    NOTE: These transmission controller kits only function in conjunction with CPP EROD/LS Engine Controller Kits. You must
    ensure the Vehicle Speed Sensor connector from the engine harness has been plugged in to the transmission Output Speed
    Sensor on the transmission
    The transmission module does not have direct connection to the VSS/OSS. Only direct connection to ECM is can network connections. I have RPM and coolant being shared. Why cant I get VSS to be shared? I've tried changing the VSS options under speedo section without success.
    Here is tune file.
    speedo change 6.hpt
    Jan 2014
    SoCal
    1,583
    Because the actual vehicle speed is calculated in the ECM/PCM not the TCM. That is why the process for tire/diff gear/pulse output is the same between manual and auto.
    Jun 2018
    Franklin NC
    35
    So what am I missing?
    Jan 2014
    SoCal
    1,583
    Quote Originally Posted by 06TrailblazerSS View Post
    From what the instructions say you need to hard wire the vehicles output speed sensor directly to the ECM. I don't have the schematic in front of me but shouldn't be to hard to perform.
    Jun 2018
    Franklin NC
    35
    The VSS is directly connected to the ECM (X1 connector pins 71&72). Thats why I'm at loss. The ECM displays MPH in scanner, but trans controller doesn't show MPH.
    I'm going loo back over the wiring and make sure person put it together did it correctly.
    7,811
    Your ECM is programmed as an automatic trans 2008 Corvette. An auto trans OS will not read a hard-wired VSS connected to the pins the manual trans OS uses. Auto trans OS is only ever going to listen for VSS coming in over CAN from a TCM.
    Jun 2018
    Franklin NC
    35
    Sensor on the transmission.
    Quote from the instructions.
    I have tried setting it as Auto and Manual under trans tab.
    Jun 2018
    Franklin NC
    35
    Another odd thing.
    The TCM doesn't show. Can't do read with HP tunes. But when use my snap-on scanner as 2008 chevy express van with 5.3L the scanner comms correctly.
    Nov 2017
    1,533
    Are you running the “engine controller kit” that the instructions call for? I think that includes an ECM? There has been discussions that these are different than the original stock ECMs. I don’t know how far that extends.
    Jun 2018
    Franklin NC
    35
    It has factory 2008 LS3 controller and harness built by novak. Has novak performance 4L60E level 3 with adaptor. The tech department at novak saidd this combo would work before ordered trans & harness.
    Another odd thing.
    Of course HP Tuners won't read the TCM, it is an aftermarket module and not factory. Powertrain Control Solutions enables the pids for scanners as if it is factory though.
    I'm pretty sure the issue is what Blindsquirrel said in post #8. The ECM must be programmed as a manual and the VSS be hardwired to the ECM. The TCM then uses a calculated wheel speed to display based on the parameters entered into the software.
    -Greg
    2009 Maverick Silver G8 GXP M6 - 586hp
    Engine Mods: TVS 2300 Magnacharger ARH 1 7/8" long tubes with catted x-pipe
    Drivetrain Mods: Ram Dual Disc Clutch
    Suspension Mods: Pedders/Wretched basic drag pack - BMR trailing arms
    Misc Mods: Jamesbiz Catch can - GRRRR8 Heater hose relo kit
    Jun 2018
    Franklin NC
    35
    Quote Originally Posted by radrace19 View Post
    -Greg
    I've had it programmed as manual and wires are hardwired to the ECM. ECM shows vehicle speed in pid.
    Calculated wheel speed in ECM or TCM software. Going go look at both.
    The TCM software will display the calculated speed. Are you using the USB cable for the TCM and the Chevrolet Performance software? Post the Chevrolet Performance .CPM file and I'll take a look.
    Jun 2018
    Franklin NC
    35
    Tried multiple times and manage attachments says cpm.file is invalid
    Nov 2017
    1,533
    Change the extension to something else that HPT will accept and I think you can upload it.
    7,811
    That means the CPP EROD ECM programmed with the CPP EROD calibration. Not a similar service number programmed as a production vehicle.
    That does not transmorgrify an auto trans OS into a manual trans OS. Wish it did, it would make a lot of things so much easier, but it doesn't.
    Nov 2006
    2,821
    I would think the ECM and TCM would have to be the original GMPP calibrations. You cannot SPS those calibrations.
    HPtuners actually works on the 6 speed GMPP trans controller. Its pretty obvious there are differences in the background you can't see as it operates differently.. TCC seems to be either abrupt on or off with them and nothing will undo that.
    But anyway.. heads up to anyone reading. you can read them with Hptuners and do quite a bit of editing that way.
    Tuner at PCMofnc.com
    HPtuners should not work on the 6L80e speed Chevrolet Performance trans controller as it is programmed with custom software. If HPT is used it might brick the TCM that is why the performance transmission comes with its own USB cable and programming software. The software is on the Chevrolet Performance website. LINK
    Actually the Chevrolet Performance TCM just pulls the broadcast CAN data from the E38/E67/E92 modules
    -Greg
