Results 1 to 20 of 20
Thread: Help with o2 code
    Nov 2020
    17
    Help with o2 code
    Can anyone tell me what i need to uncheck so i will not get o2 sensor code before i install long tube headers? i seen it on this site somewhere and now i can't seem to find it..Thanks
    Nov 2020
    17
    I am keeping the upstream o2 sensors..Just need to delete the downstream ones.
    Feb 2020
    37
    Not sure what exactly you are working on, but on my 2016 Camaro there are 32 codes that need to be unchecked and set to No Error Reported. Everything to do with 'sensor 2'. Pretty sure all the stuff related to this gets taken down.
    This is what I have in my notes
    Not in order: P0036 P0037 P0038 P0056 P0057 P0058 P0141 P0161 P0137 P0138 P0157 P0158 P0054 P0060 P013A P013B P013C P013D P013E P013F P014A P014B P0420 P0430 P2096 P2097 P2098 P2099 P2270 P2271 P2272 P2273
    May 2003
    South FL
    1,369
    You also need to disable the cat efficiency codes
    [email protected]
    Owner/GM Calibrator
    Feb 2020
    37
    I added my list to my earlier post
    13,565
    Don't forget the cat test and the post o2 sensor test if available in the engine diags exhaust tab. Only older software versions will show those two.
    Nov 2020
    17
    sorry i forgot to put that im working on a 2016 silverado with a 5.3 in it
    Nov 2020
    17
    i tried to uncheck boxes but it just highlights them..the codes are like in a gray area and are checked.
    Feb 2020
    37
    That's part of the new EPA agreement with HP Tuners. You have to take an online class to get access to those parameters. I'm on the old 4.4.4 and probably wont upgrade unless I have to down the road.
    Nov 2020
    17
    what site is the class on? i really need this done
    405
    2,326
    If you are using a version of HPT that requires the class it's not going to let you disable everything you need to even after completing the class. See post #6.
    Feb 2020
    37
    ^ What he said, but... it's at HPTUNERS.COM>RESORCES>EMISSIONS
    Nov 2020
    17
    i wish i had the old version..i tried backing up my laptop but it won't let me
    Feb 2020
    37
    Well, the down side of the older version is it doesn't work with the new hardware as I can't look at any of the new logs or tunes that people post here. But I'm only tuning my car so it's not holding me back.....yet.
    Feb 2006
    PAC NWest
    396
    You can run multiple versions on your computer.
    Feb 2020
    37
    Quote Originally Posted by gottogo View Post
    I thought it would overwrite the older version.
    Feb 2006
    PAC NWest
    396
    There's a thread on it somewhere.
    I think you rename the first install folder then install the second.
    Feb 2020
    37
    Thanks, I'll look into it.
    Feb 2020
    Central VA
    54
    I took the test and got "Certified" and then upgraded to the latest Beta and I could disable all my downstream O2 codes.
    2017 Camaro SS, Flow Tech axle back, Roto Fab, Nick Williams 103 TB, BBK long tube headers, Magnuson 2650, Snow Performance Water/Methanol Injection.
    Nov 2020
    17
    I did the same thing..thanks for info everyone.
