Originally Posted by
LS ROB
As mentioned above; fix injector data first! The WOT log you posted showed lots of spark retard. The timing needs to be addressed so you can safely tune your engine. Your low octane table has more timing than your high octane table in the area you spend alot of time in. Honestly, the tune is worse than stock. I dont think it even hit 380Ftlb of torque. I have the TSP 2.0 for ls7 and you should definitely be making a ton more power than what i seen from the log. Not sure of all your mods but stock is 480ish. I'd look into getting one of these guys from the forum to get it right.
