Results 1 to 10 of 10
Thread: Bone Stock 5.3 (truck) with P01 PCM O2s only reading 450-480 no change.
    Feb 2021
    Houston, TX
    53
    A buddy of mine has a stock DBC 5.3/4L60 in his 56 Bellaire. Engine runs great, but does not trim due to the O2s staying at 450-480 all the time. I loaded a complete stock tune in it with the same OS thinking something was turned off keeping it from going into CL, but nothing changed. We replaced both O2s and still no change in the MVs. Could this be a grounding issue through the O2s?
    Dec 2019
    MS
    567
    Possible Oxygen Sensor ground or power issue.
    Have you checked for power at the connector?
    Feb 2021
    Houston, TX
    53
    Quote Originally Posted by RDF1 View Post
    Not yet, we ran out of time the other day. I'll have to get him back over here to do some more investigating. Does anyone have a diagram to the pinout on a 2004 1500 upstream O2? (square white 4 wire plug)
    Feb 2021
    Houston, TX
    53
    Thank you! We'll line it out. I see [High signal---Low signal---Heater---Power] Are these grounded through the exhaust?
    Dec 2005
    Texas
    254
    Quote Originally Posted by Mingus View Post
    PCM provides ground circuit
    Nov 2017
    1,464
    Heater LOW CONTROL is ground controlled by the PCM, when it wants the heater on it completes the circuit by grounding it.
    Heater low control is ground for the PCM, sometimes called low reference by GM.
    7,643
    And low signal is the ground reference for the signal side, it uses that as the 'zero' against which to measure the signal voltage, since there can be pretty significant ground offsets between true battery ground, ground for the power circuits of the PCM, etc. Difference between high signal and low signal = O2 voltage.
    The NB O2 is essentially two electrical devices inside the same package - a 2-wire sensor, and a 2-wire heater.
    Nov 2017
    1,464
    I need to pay more attention to what I'm typing. Meant to say "Sensor Low Signal is ground for the PCM..."
    Feb 2021
    Houston, TX
    53
    That makes sense. I'll get with him here in a few weeks and check all the wiring.
    I attached the files if you want a look.
    5.3-4L60 O2s faulty.hpl5.3-4L60 O2s faulty.hpt
