Results 1 to 9 of 9
Thread: 2012 ZL1 Lazy Throttle
    Mar 2023
    3
    Looking for some input/advice,
    I recently changed the cam, exhaust, pulley etc. on my 2012 ZL1 and after some tuning by a local "professional" it seems to run and idle faily decent. I havent run it much yet, just took it out and logged some part throttle data. Issue is the throttle seems "lazy" on the bottom end and at take off. I myself made some changes and its better, and possibly the best it will get with the engine mods.
    Wondering if someone has run into this before or could look at the tune, and log to see if there are any other changes that could or should be changed.
    BTR Stage 4, 235/252, .628/.600
    2.5 Pulley with mild porting on the snout
    1 7/8 long tubes, high flow cats with 3" and no mufflers (currently)
    Revision3.hptPart Throttle.hpl
    2012 ZL1
    BTR Stage 4-235/252, .628/.600
    BTR Springs, retainers, pushrods
    2.5 Pulley with mild snout porting
    1 7/8 long tubes, high flow cats, 3" and no mufflers
    160 Thermostat
    MGW Shifter
    Aug 2006
    Arizona
    244
    Helps if you provide the .hpt file as well
    2009.5 PBM G8 GXP M6 W/Roof-Self tune, OBX LTs, Kooks axleback, LSA blower, cam,
    Monster LT1-SC clutch, flex fuel, 12 psi [email protected] 1,800 D.A
    2007 TBSS-Self tune, bolt ons [email protected], 1,900 D.A
    1991 GMC Syclone- Self tune/catback 12.8@104, 4,200ft D.A
    Nov 2017
    1,464
    Quote Originally Posted by STAGEUP View Post
    He did, just no space showing before the log file so it looks like one file.
    7,643
    I thought the whole purpose of the big-huge PD blower cams with super extra wide lobe separation was to make the low end soggy as hell, for traction or whatever, in exchange for more top end where the blower starts to hit the efficiency wall?
    Mar 2023
    3
    2012 ZL1
    160 Thermostat
    MGW Shifter
    Tuning Addict
    Jan 2015
    6,802
    Honestly can't believe you paid for that, but whatever... Add some timing in the lower load ranges. Just extend that hump in the factory timing table on up. That will take care of a lot of it. You can also tweak other things like PE some more to aid it. Biggest benefits will be a TB upgrade and cai if you don't have one, but you'll need injectors at that point.
    ~Greg Huggins~
    Mar 2023
    3
    Thank you, I've added some timing already and its getting better. It isn't bad, we've all driven bigger cams, I was just looking for the "perfect" set up if anyone has come across it yet.
    2012 ZL1
    160 Thermostat
    MGW Shifter
    7,643
    I apologize sincerely for getting a little chuckle out of reading "Hi I installed a huge cam and now my low speed is bad help please". I should not have done that. I am a bad person.
    Why is this GEN4 post in the GEN5 section?
    Bo Woody owner:
    APS Automotive
    www.apstuning.com
    Oklahoma City, Oklahoma
    405-424-RACE
