Results 1 to 6 of 6
Thread: Cold startup very rich and hanging RPM
    Apr 2023
    12
    Hi everyone,
    New to GM and HP Tuners so thanks for the patience in advance .
    E38 ECU, 2 bar map, LS3, mild BTR cam, no cats, SD only.
    Attached are two logs and a copy of the tune.
    The cold start log is up to thermostat open
    The hanging idle is a warm start and you will see I slightly touch the throttle and it hangs around before coming back down.
    Anyone willing to share some pointers?
    13,565
    If it's a 2 bar MAP sensor, you should put the 2 bar MAP sensor values into the computer. The tune still shows that a 1 bar map is installed.
    Apr 2023
    12
    Actually I think I am wrong - I saw under "OS" it listed the 2 bar map as an option and assumed that is what was installed? But I do not think that means it's installed?
    Map is a P/N 55573248
    Aug 2018
    20
    Reduce the open loop fueling table by quite a bit, try reducing by 25% at a time and as far as the hanging throttle - I'm not real familiar with that OS but on my E67 I played with reducing the BRAF and the idle step down values to get to allow lower rpm idle and to step down faster after a throttle blip
    Jul 2012
    MANITOBA,CANADA
    99
    I had a similar vehicle with the same mods and similar issue. Try this tune,, I modified yours so you can just write it after you do a compare to see what I changed. Let me know how/if it worked
    2010 /2SS/Long Tubes/ Magnaflow axle back/LSA Conversion/ 2 bar OS running / Stock Blower Pulley...for now
    Apr 2023
    12
    Thanks for the file! Finally got car running again to test this out. It seems to have helped the cold startup issues.
    I took the car for a 20 minute drive and took a log. It's attached as well as a copy of the running tune (same as your file, just read back). From what I can see the ST fuel trims are pretty close except for a few areas in the +10 to +20 range.
    I presume I take these trims and apply them to the base fueling table to bring it closer? I also see a ton of ignition advance being called for - it is a bit surprising it's calling for >40 degrees -- is this normal?
    may 21st first drive.hpl
    Miata-Running-May-21.hpt
